soldering 9920 to 9xl
What is the best way to solder your motor to the controller "wire to wire" Should you use a butt connector and solder it , or should tou solder the wires together directly?
use 5mm gold connectors for ease of things.
Yup 5.5mm connectors are the way to go for this. Mke carries them ;)
is it possible to use 4mm connectors?
because I've got those laying around. |
They won't fit the motor. The motor should come prewired to 5.5mm females, so all you need is 3 5.5mm males plugs. They are about the best and easy to solder and give great connection!
I never had a problem with the 4mms. technically the 5.5 connectors will handle more amps but the 4mm never heated up or anything when I used them so they were fine. I used 4mm for a while and then switched to the 5.5 only because the Quark came with 5.5 and it was a pain having some motors/controlers using 5.5 and some using 4mm. So I switched all of them to the 5.5s. Now I can swap motors from vehicle to vehicle with no hassles. Just plug and play. |
I'm running 4mm on my 7xl just because the mm esc already had them and I had the males in my box already.. seem fine to me never hot..
phil |
If you solder directly You don't need a butt connector.
You can use one to make it look neater. You can go with the 4mm plugs since you have them. |
| All times are GMT -4. The time now is 06:02 PM. |
