-   -   MM 25 amp Cut off (https://www.rc-monster.com/forum/showthread.php?t=5196)
neweuser 01.08.2007 06:22 PM
MM 25 amp Cut off
What should this be set at? I run the 2s in the comp x, but the 2s cut off is 6v? otherwise the nimh is 4v? Which should i use?
thanks!
crazyjr 01.08.2007 06:31 PM
6 volt cut off because thats the 3v per cell limit
neweuser 01.08.2007 06:46 PM
Ah, i see how they are saying it now. Instead of saying 3v (per cell) they say 6v for all....thanks crazy!
crazyjr 01.08.2007 06:52 PM
No problem
Sylvester 01.08.2007 07:25 PM
Yea, they would make it alot easier just saying 3V per cell, first time i checked the MM manual i was like, wait, 6V cutoff?!
neweuser 01.09.2007 10:03 AM
I had the same reaction, which is why I asked. I had it set to the 6v to be safe....glad I was right in my initial thinking!
crazyjr 01.09.2007 04:09 PM
Even if it did it would need additional programming, like, cut-off 3v per cell, then, how many cells.
The way they have it there is less programming and still determines proper cut -off, the way you suggested is easier for everyone except for the programming people
Also takes up valuable memory
neweuser 01.09.2007 04:17 PM
I agree with you crzy. It was just different is all. If it would have mentioned that in the instructions on what the cut off meant would be nice, then it would clarify as well without the additional programming, jsut an idea as most companies list the cut off per cell, so that is what I'm used to. But I like the idea they have with listing it as a sum.
