-   -   well... there ya have it. (https://www.rc-monster.com/forum/showthread.php?t=5224)
revopqrs 01.10.2007 05:27 PM
so ofna 9.5, violator, mutilator front shocks are a direct replacement for the stock maxx shocks. nearly indenticle... the ofnas are maybe a 1/8" longer than the maxx shocks.
i used long rear springs so i wouldnt have to run so much compression on the adjuster.
buttery smooth, and just the right amount of preload. im using medium ofna springs and 45wt oil.:028:
sooo... what that means is you can get the same shocks UE sells, for less than 1/2 the price!! they are in stock, and they even come with the studs!! lol.. i saw a used set of 8 UES just now, bidding up to $195!!:eek:
you could get 8 ofna shocks for $100.:027: NEW!!!
shhh... dont tell everyone!! lol..
http://cgi.ebay.com/OFNA-MUTILATOR-T...QQcmdZViewItem
i even tried out a set of ofna 13mm big bores(best in the business) they fit fine too, just use the fronts with stock towers. but i need those on my jammin!
they are more expensive...
http://cgi.ebay.com/OFNA-JAMMIN-X1-C...QQcmdZViewItem
the rear ofna shocks are close to an inch longer FWIW.
http://www.mvbashers.org/gallery/dat...um/flm_093.jpg
revopqrs 01.10.2007 05:46 PM
heres a pic of the 13mm big bores, front. they seem to have plenty of clearance through the stock arms...:027:
http://www.mvbashers.org/gallery/dat...um/flm_096.jpg
Serum 01.10.2007 05:54 PM
Well, you pay 144 bucks for 8 new UE's, which come with 16 springs in total, mounting hardware, (the aluminum spacers) nitrid coated shafts and some spare parts.
I don't consider that very expensive?
revopqrs 01.10.2007 06:27 PM
cool, if your happy payin $150 for shocks... ive never paid that much for shocks and ive been playing with these a LONG time, im 36. that just seems unreasonable to me... but i guess nearly everything for the maxx is unreasonable! there would have to be something cool about em, the 12mm ofna shocks are very standard. they dont even have bleeder holes.. i do like the TiNi shafts tho... i wonder where they found them? you dont see em on buggies for some reason?
i guess this way works for me because im into buggies, i have these things layin around. i only had to pay $25 because i already had a 1 set. i plan to only run 4 shocks at this point... unless the need arises to up the damping, ride height is fine.
i was about to get the power strokes just because theyre different.. but then a buddy had a set of the 12mm ofnas so that settled it!
the big bores would still be far better than these 12mm ofna/UE shocks tho!! but they are closer to $50 a pair.
just tryin to show some people how to do it on the cheap!! you can get 4 from ebay for $50.:010:
GorillaMaxx360 01.10.2007 06:41 PM
Cool glad to see they fit.
Procharged5.0 01.10.2007 08:42 PM
TiNi shafts are pretty common on shocks. Team Losi has been doing it for over a decade on their top level kits.
revopqrs 01.10.2007 09:06 PM
ya i know about them for monster trucks, but ya dont see em on 1/8th buggies? i wonder why.....
Procharged5.0 01.10.2007 09:20 PM
It makes alot of sense. Superhard coating, minimizes shaft & seal wear.
There are better coatings available such as Diamonex, Casidiam, and a few other but they are not as cost effective.
Mike.L 01.11.2007 09:28 AM
if i ever build a maxx again then im getting the hb lightning shocks.
