Where to buy shrink
I want to buy some shrink. I notice maxamps has it.
They won't take an order for just shrink. Does anyone tell me who sells it right off hand? something maybe can pic up. |
What size and color do you need?
Adhesive lined or regular? |
1 Attachment(s)
McMaster is one of many sources....
here is a pdf to get you started. |
If you are talking about the stuff on the outside of the lipo packs I have bought it from TrueRc.com. The stuff I got there was nice and thick and tough. I have bought some from ebay once, but it was really thin and crappy.
If you are talking about the small stuff for wires, then any hardware store has it. |
Didn't know they had so many kinds.
I want some to cover a set of wires. It needs to be about the size that comes with the quark. Black would be fine. Not to worried about being perfect. |
How much do you need?
I have some in the warehouse I could mail to you tonight. Just need to know what size wires your covering. Give me a diameter. Buy most autoparts stores, home centers, hardware stores, and marine supply houses sell it. It should be easy to find. |
Does radio shackshack have this?
How do you measure like the diameter of it or flatten it out and measure across?
Just hold a ruler (tape measure, etc) across the wire and "eyeball" the diameter. 12g wires are 3/16" maybe.
Heat shrink shrinks to about 50% of its "unshrunken" size so 1/4" shrink covers 1/8" to almost 1/4" dia wires....for example.... |
Well in that case. I would need in the 3/8 range or better.
I measured a small piece I had. It looks like flat 13mm across would work if laid out flat. I need in the neighborhood of about 100 mm long. Do you happen to know if the radio shack sells this stuff? I could hit a store tomorrow. I be in town near one. Gee. That sounded countrified. :D |
BTW, don't hit a store...you'll get arrested and we might (just maybe) miss you. :032: :005: |
| All times are GMT -4. The time now is 03:28 AM. |
