HB diff question
Will the UE driveshafts work with the HB diffs?
Yeah should. I don't see no probs.
Would I use the ue drive cups or would the ue cvds fit the cups on the hb diffs?
I would use UE cups with UE shafts, the reason is simple; the UE shafts use long pins, to divide the stress in the cup. (larger contact area) The cups are designed with a thicker part in it. So the UE cups/UE shafts will be more durable in terms of wear.
| All times are GMT -4. The time now is 10:46 PM. |
