-   -   Anyone here running 8s LIPO? (https://www.rc-monster.com/forum/showthread.php?t=5261)
hyperasus 01.12.2007 09:14 PM
Anyone running 8S Lipo? Reason I ask is because I just had a great breakthrough on my rusty/pede heat problems. I had an 8000mah 3S2P $170 maxamps battery I let run to low and wrecked one of its sells. Since it was wrecked, I decided to just turn it in to a 4000mah 4S. After running it in my pede(MM ecs & Lenher Basic XL motor), it doesn't get hot anymore. Heck, it hardly even gets warm. So. Now I am a VERY FIRM believer in using high voltage. I have a huge stack of Maxamps 2S2P LIPO's I now want to convert over to 4S. I am in the process of getting a G2R Revo. So if I converted all of my batteries over to 4S(I have 5 8000mah and 4 6000mah 2S2P) then I could use the same packs in both my rusty/pedes and my Revo. Just use 2 packs in the Revo. So that’s why I'm wondering if trying to run a Revo on 8S is going to be realistic. What do you guys think?
One more thing. When Mamba Monster Max comes out I want to get one for the Revo. Any chance it will be able to handle 8S lipo?
coolhandcountry 01.12.2007 09:35 PM
To my understanding the mmm is supposed to take 8s lipo.
You just need a motor to run close to 35000 rpm with that voltage on it.
I have ran 26 cells of nimh before going lipo.
I am getting ready to test 12s limn out on a gtx2.
hyperasus 01.12.2007 09:47 PM
Would a Lehner 1940/10 be slow enough for 8S lipo?
crazyjr 01.12.2007 11:19 PM
The MGM 16024 can do 8s as well
hyperasus 01.12.2007 11:57 PM
So noone here as actually run 8S lipo? Thats surprising.
Coolhand, which motor and controlller did you run 26 cell on? How did you like the high voltage?
starscream 01.13.2007 05:50 AM
I've run 8S Lipo with the CC HV110 and a 12XL on my G2R
As I've mentioned in other threads, the HV110 had a little feature that forced me to give it up :007: :007: :007:
I was a little apprehensive plugging in 8S the first time (lots of power there). The 12XL got hot pretty quick though. I just bought a MGM 9032 which will work with pistal grip TX's. Once the MGM arives, I'll try 8S again.
coolhandcountry 01.13.2007 09:01 AM
I ran a 36120 bk micro.
Promod around here runs 9s lipo as well.
Startscream: Is that a 90 amp esc rated for 32 cells? Let me know how that works out.
Did you consider the 3695 mike sell to?
captain harlock 01.13.2007 11:54 AM
From my understanding, Promod was not able to keep his SuperMaxx on the ground with the 2240/10 and 9s.
danverz 01.13.2007 02:34 PM
The Kontronik Power Jazz is able to handle lipo 15S, 120Ampere with 200Ampere of peak but it's not cheap :)
They say it's bullet proof ... they say you can have cables as long as you want ...
they say it has a inversion polarity protection ... they say it's "antispark" pluggable ...
and a lot more.
On the paper it seems to me to be really a First Class ESC.
I don't know about the brake and the reverse.
http://www.kontronik.com/Powerjazz2006e.htm
Ciao,
Daniele
Serum 01.13.2007 02:53 PM
Hi Daniele! long time no see!
I mentioned that controller a week back; Daf heard it was without a proportional brake! which is bad for a car-controller.
starscream 01.13.2007 03:13 PM
Leroy, Yes its 90AMPS 32CELLS
The Power Jazz looks great but the MGM I got was over half the price so I'll see how it goes. The proportional brake isn't neccessary for me since I'm using manual brakes. :017:
captain harlock 01.13.2007 03:54 PM
What do I need to make a Mechanical brake?
Is it possible to use it with a Slippy equipped SuperMaxx?
starscream 01.14.2007 12:06 AM
Leroy,
I definetly considered the 3695 from Mike but the BK won't work with the NEU mtoros so I went with the MGM.
captain harlock,
This is totally unofficial but RCM may be looking into this for the slippy.
crazyjr 01.14.2007 12:59 AM
Brakes? on a slipperential???? cool, I hope he starts with the Revo version, I'll take two
coolhandcountry 01.14.2007 09:03 AM
That expalains the extra holes on the mount. :D
I got it now.
