-   -   Lipo configuration (https://www.rc-monster.com/forum/showthread.php?t=5280)
captain harlock 01.14.2007 12:32 PM
Lipo configuration
Guys,
My 149.18 controller has four battery leads, two reds and two blacks.
If I use the two 3s packs I have like that, it means I'll double up the cpacity and not the voltage.
I then thought that I could actually connect the negative lead from pack one with the positive lead from pack two and make all four leads of the controller into two main leads which will connect to the remaining leads of the two 3s packs.
I did it and it worked quite well, but...in the long run, will I face some sort of malfunction in the lipo's performance?
Is it possible that a shortening might occur?
What about the possibility of discharging some voltage from one pack to the other in the process?
Thanks,
Alawi El-Jifri..:)
captain harlock 01.14.2007 02:17 PM
Need some help here, BTW..
Sylvester 01.14.2007 02:28 PM
I doubt there will be any malfunction with the performance..
It shouldnt be a problem since you arent experiencing any problems when you ran it, and i doubt over time any different will occur, your balancing your lipos too , right?
MetalMan 01.14.2007 10:28 PM
You put it in series :). Simple as that :).
Procharged5.0 01.14.2007 10:48 PM
I see no problem with that!
captain harlock 01.15.2007 08:02 AM
It just got me worried a bit.
Thanks, though.
