One lightweight savage conversion.
4 Attachment(s)
18 grams on the motorholder to be precise..
planning on putting together a fair lightweight basher (as far as possible with the savage) CF battery trays are in progress. Getting some CF hingepins shaved off a decent 70 gram.. Using the 2 speed transmission (heavy duty 2nd speed), mechanical heavy duty brake, Hotbodies C8019 cups, GPM/Dynamite aluminum housings. |
Thats light! Looks good Rene! Is that the extended chassis?
Lets see some lsp battery trays! ;) |
No, just the short one! the extended doesn't fit a shell nicely.. and it's very long.. i like the short wheelbase for a basher to be honest.. makes it nimble and easy to control in the air..
LSP trays? what do you mean? i am working on some carbon fibre trays.. |
The "ultimate" trays you were talking about in another thread ; ill show you mine once it is done, involves nylon, aluminum and a bit of machining..
I agree with the short wheelbase.. not needed for bashing. Its also lighter too! |
Ah, yes, that are the ones for lipo-packs.. This truck will use nimh cells.. it's better suited for bashing IMO..
It really depends how the batteries are placed, and how hard you bash;)
That's what i said; NIMH... no matter where they are put, for bashing i put more trust in nimh than in lipo.....
looks nice and its lighter....what more!:p
Does it let the motor have any flex?
There is a plate under the motor leroy so i doubt it would have any flex.
No flex.. Stiffer than the other plates i made. can't go up/down or left/right
It looked so far back on the motor.
I thought it may have let it move or flex a little. It is good to know it don't though. |
1 Attachment(s)
Here; this explains..
You should try and mount a center diff. It would be lighter than the bulky Savage tranny.
Very nice chassis lookes light.
| All times are GMT -4. The time now is 11:23 PM. |
