-   -   Fried Hv-maxx, what now... (https://www.rc-monster.com/forum/showthread.php?t=5298)
Ozmaxx 01.15.2007 01:41 AM
The short story is that I fried my novak esc and I need a new set up. The 4400 was boring me bit anyway. Here is what I have -
MIP CVDs all round
Steel idlers
Alloy diff cups and diff cases
Alloy Bulks
2 speed transmission
RPM arms, towers and skids
Only been running 12 cell 4000mah nimh (still got 3 sets that are good)
I want a good reliable setup. Had the 9920 in mind, but not sure what motor to run, 7xl, 8xl, 9xl etc.
Which motors run well on a lower number of cells, 12 -14?
Is it worthwhile to get an extended chassis and take more cells? I mean I'm going to be spending on a new setup anyway.
Any suggestions would be great.
BP-Revo 01.15.2007 02:27 AM
The 7XL runs well on 12-14 cells.
Call Novak up on the ESC...I'm sure they will help you out. How did it fry anyway?
Personally, I'd give the new HV4.5 a try...should be loads faster than the 4400...my 6.5 feels faster than the 4400, so the 4.5 should be waaay faster.
Ozmaxx 01.15.2007 05:58 AM
Ok, done some more reading, a I think the 7xl seems right. (thanks BP-Revo)
Would 20/66 gearing be a good ratio on this truck?
What dia shaft is the 7xl?
Do I need to order a UBEC if I only run 12 cells?
What sort of top speed would I be looking at with 20/66? The calaculator says 34 mph....
Thanks
Ozmaxx 01.15.2007 06:48 AM
Don't worry, there are none in stock anyway.:035:
