BK9920 on HRS mode
Does anyone know if there are complication running 9920 controller with Futaba's HRS mode? I heard schulze or another brand (i forgot) requires the TX/RX to run PPM. Is this the same with BK controllers?
I never heard of problems with the 9920 and digital receivers.
Cool, thanks Rene just thought i'd ask to be sure :)
Are there gonna be some problems with the HRS and Schulze controller?
I have the 3PK/HRS and Schulze 149.18 controller. You think I have to use the normal PPM receiver? |
My schulze worked with the digital receiver i had..
I don't see where there would be a problem with ANY system. Whether it is digital, AM, FM, super-nova radioactive (:)), it's all about the signal transmission. The servo/ESC output of the receiver is always the same; 1ms to 2ms pulses on a ~50Hz (20ms) square wave frequency. This output has nothing to do with the transmitting method.
There shouldnt be a problem - just one thing i had with the Spektrum ; run a SWITCH! I had mine let loose and burned my whole hand (with a little help from my friend mike;)) If your gonna run a UBEC (very reccomended) than run the switch between it and the receiver - other than that no problems!
| All times are GMT -4. The time now is 10:43 PM. |
