-   -   Mamba Max motor possible mis-labeled? (https://www.rc-monster.com/forum/showthread.php?t=5388)
fiero_silva 01.21.2007 01:19 AM
Well, I've got my Mamba Max setup running around in my jato with the 7700 motor..... Way way way slower than I expected with any battery I used...
Gearing is good, I get about a 14:1 ratio in 1st gear, and a 10:1 ratio in 2nd from the pinion to the wheels... It's just slow as stink :(
Top speed is slightly faster than a brushed motor, but nowhere near the power to weight ratio or top speed that any of my 18th scale mambas have.... My Mamba'd RC18T would smoke this thing in every aspect, acceleration and top speed.
Is it possible my 7700 is not actually a 7700 but one of the lower kv motors? Could this explain the seeming lack of RPM?
Specs:
Jato, stock 2 speed trans, diff ect
55t spur
15t pinion
Mamba Max ESC
MAmba Max 7700 motor
GP 3300 cells at 7.2v
Deans connectors
And honestly, I'm very very dissapointed in the setup... Everybody is praising this thing and IMO it sucks :(
Bomb-Proof 01.21.2007 01:33 AM
what temps is it running, how good are your packs?
MetalMan 01.21.2007 01:35 AM
Are your battery packs stick packs or side by side?
Have you calibrated the throttle with the endpoints on your radio set to full?
If all else fails, you can contact Castle on Monday and ask them what might be going on.
BrianG 01.21.2007 01:40 AM
I suppose it is possible, but unlikely. You could contact Castle and see what they say.
Even if it was mislabeled, you should still get some very good speed with the 4600 or the 5700. I'm getting a little over 45mph with the 4600 on 2s with wheel-spinning torque in my Jato. I even have the start power turned down and timing as low as possible. I can't imagine running it on 3s!
The 7700 is a very hot motor. That would probably be a 3 or 4 turn motor using the kv ratings of similarly sized S motors. Therefore, your batteries are probably unable to provide the current needed to get that moving under load. Sometimes it's bette to use a lower kv motor for extra torque and simply use higher voltage to get the speed you want. Plus, the added torque from the higher turn motors tend to be a little more forgiving with misgearing.
fiero_silva 01.21.2007 02:16 AM
Side by side packs. EPA is set to full.
That seems like a logical explaination, however I am experiancing no cogging at all... I would expect to see some cogging at a minumum if the batteries were not good enough?
What would one recommend for a lipo-pack? I'd like to run 3s at a minumum.......
Just for kicks, I tried 14.4v just a few minutes ago, Iirc motor was 110ish, speed controller was 165. Speed is better, but definatly nowhere near what it should be....
glassdoctor 01.21.2007 02:41 AM
Lack of cogging is not an indicator that the battery is "good".
14.4 on a 7700 won't work in your truck... was way overgeared. Besides, 14.4 will destroy any 7700kv motor if you let it spool up.
If you hold the truck in the air and give it full throttle do the tires balloon way up? With 7.2 or 14.4?
Serum 01.21.2007 04:36 AM
What brand/type of batteries are you using?
Bomb-Proof 01.21.2007 11:22 AM
you cant compare grapes to oranges. The 18th scale stuff is in a class its own, they are weightless and super fast, and sound totaly different. Junk cells will still make them fly, gearing can be off and they still fly. 1/10 you have to start using your brain a little, and in monster trucks even more so.
You are one of the 1000's of people that looked for the highest # expecting the faster set up, and those motors are not the way to go. Sounds like you have generic batteries, which are probably the entire problem. You also need good soldered joints and really good connectors.
What we need to know...
How fast in MPH to do want to go?
BrianG 01.21.2007 12:14 PM
Not necessarily. Cogging is simply the ESC not being able to determine where the rotor position is by the back-EMF pulses. If it's turning, however little, you won't cog. What I'm thinking is that you are getting a large voltage drop on your batteries under the heavy current the 7700 requires. Oh, and you defintely don't want to run that motor at 14.4v, that's almost 111,000 rpm!! :eek: ...assuming of course that the batteries actually stay at 14.4v.
If you're looking for batteries for that setup, I'd go with something that has a large Ah and/or C rating to be able to supply at least 100A continuously with minimal voltage drop. Otherwise your lipos will heat up fast and may be damaged.
Personally, the 7700 is not sized right for that truck. Maybe in a 2-3lb vehicle. Don't forget; as kv goes up, torque goes down and that motor may simply not enough torque to get the vehicle moving at a decent speed. Again, I'd say go with the 4600 or lower kv motor, use higher voltage, and gear appropriately. I am almost positive you'll be satisfied.
fiero_silva 01.21.2007 02:23 PM
Tires barely baloon with the truck in the air on 7.2v.
Tires baloon reasonably with the truck in the air on 14.4v.
GP3300 cells in built 7.2v packs. 12awg wire, deans connectors.
The same, if not FASTER than the Jato was originally with the 3.3 motor in it.
fiero_silva 01.21.2007 02:30 PM
Yah, I'll most likely be buying the 4600 motor shortly... Oh well, My stupid mistake in buying the 'fastest' motor from the get go...:007:
I guess I'll have to find a 'lightweight' 2-3lb car for the 7700 to go in now... Maybe a light weight land rocket of a road car or somthing :)
Basically what I want, is for the thing to be almost undriveable because it has so much power... I want it to be stupid fast, wheely on command and be a challenge to drive because it has so much power........
glassdoctor 01.21.2007 05:20 PM
Maybe the Jato tires are different, but most tires would balloon huge on a 12 cell 7700kv setup..... at any gearing. Something still doesn't sound right. Even the 4600 on 12 cells would be very very fast.
But you do know that going faster than a Jato 3.3... 65mph... isn't that easy. If that's what you are comparing your truck's performance on, then I can understand it seeming "slow" to you, since it's not a "proper" setup. Get it right and it will be fast.
I would suggest getting a good 4s lipo to go with a 4600MM if you are serious about besting a Jato 3.3.
BP-Revo 01.21.2007 06:39 PM
Yea...65mph is pretty difficult without the right stuff. I might even suggest throwing a Lenher 1940 in there and running it on 4S. That should get you the 65mph no problem.
BrianG 01.21.2007 07:03 PM
Holy cow! A 1940 in a Jato? I would think a 1920 or 1930 would be plenty. Then again, it would certainly do the job! :)
BP-Revo 01.21.2007 07:16 PM
He wanted something uncontrollable :D
Or...maybe a 3080 on 12S LOL... That'd turn a SuperMaxx driveline into tossed salad at 1/4 throttle.
PS. A 3080 is one of the largest lehner motors available...It has something like 1100kv lol...
