quick question
i got my 9920 wired up with an UBEC and was just wondering which wire to remove from the esc to receiver wire. thanks.
none! remove the black tab from the back of the controller, its under the shrink wrap.
You can see it as a small rectangle on the battery end near the red wire in the shrinkwrap
Cant you just disconect the red (middle) wire also? It should do the same thing as far as I know.
yes you can do it that was as well, I used to do that, but since im using I lipo saver now, I opted to just leave the red wire & to pull the bec plug, either way will work
i dont think so, cause it needs to read the voltage correctly from the lipo's is my guess, so i just pulled the black jumper
It has 2 separtate wires that go directly to the pack leads. Thats where it reads the voltage from. The 3 wire plugs are for control signals and 6v power only. It doesnt read voltage from there. It would only read the 6V from the BEC on those wires.
I'm just not sure what it deos to ''cut off'' the power to the esc. Does it just shut it down? or just block the signal pulses from the Rx to the ESC? Does it need the red wire to do this? |
alright thanx guys. what happens if u disconnect the black jumper and the middle wire?
@meatzardd: It should just be a redundant way to disable the built-in BEC...
| All times are GMT -4. The time now is 11:18 PM. |
