-   -   my try of a watercooled savage (https://www.rc-monster.com/forum/showthread.php?t=5451)
rhylsadar 01.25.2007 03:59 PM
hi
here is my savage that i modded to a watercooled system.
components: bk 20120 wk, wanderer 9XL, 20cells, gearing 20/52 (fixed in first gear). a rc colleage of mine has modded his schulze 18.97kw (pics below) to used it with watercooling for his bl mp 7.5.
in my frist try i used a nitropump from sullivan that works from 6v - 12v. the powersource was a 2s liion battery pack. i tried the setup since september 06. so the hardcore test in summer is still missing. but with outside temps around 20° i didn't need the pumps so i took it away. now i only have this small "handpump" that i push a few times when changing batteries.
the radiator is made out of two small copper parts with two copper heatsinks that are used for the ram blocks in pc's. some little antioxidant in the water.
the equalisation tank is also from sullivan. its a 1oz small flextank (you can heat it up and form it).
experience so far after about 25 runs. the controller is the coolest part and never got over 60° even after two 20cell-runs. so i had no temp issues so far. the motor got quite hot (70°). i have to say it wasn't on a track but bashing in the gravel pit. at a track with nonstop power it may be different.
the truck is quite heavy (around 8kg). of course i made the "usual" strengthening mods (alu diff cups with slide blocks, trimmed cups for two extra outerbearings in the alu bulks, big center cups and shafts, 4 pin mod on the gearshaft etc). i also fabricated a nylon rollbar out of an FG roll bar.
the truck holds up pretty good till now. the next step is to include the motor in the water circuit. i couldn't do it yet because i have gotten the wrong mantle from bk. 6S lipos would may bring the weight somewhat down. maybe i will switch the motor to a 1950 lehner.
bye
rhylsadar
the controller
http://62.2.107.106/~beat/images/10-10-05/warrior5.jpg
the radiator
http://62.2.107.106/~beat/images/10-10-05/cooling.jpg
front
http://62.2.107.106/~beat/images/25-01-07/wcsav_(1).jpg
rear
http://62.2.107.106/~beat/images/25-...wcsav_(20).jpg
side
http://62.2.107.106/~beat/images/25-01-07/wcsav_(2).jpg
http://62.2.107.106/~beat/images/25-...jan07_(32).jpg
downside
http://62.2.107.106/~beat/images/17-...mn06_(182).jpg
the 4 pin gear shaft
http://62.2.107.106/~beat/images/25-01-07/jan07_(8).jpg
http://62.2.107.106/~beat/images/25-...jan07_(10).jpg
trimmed diff cups
http://62.2.107.106/~beat/images/17-...mn06_(135).jpg
trimmed 43t (left) to use a 8x16 instead of 10x16 bearing
http://62.2.107.106/~beat/images/17-...mn06_(150).jpg
diff
http://62.2.107.106/~beat/images/17-...umn06_(91).jpg
trimmed bulk (shown on the plastic)
http://62.2.107.106/~beat/images/17-...umn06_(89).jpg
the pump
http://62.2.107.106/~beat/images/17-...umn06_(63).jpg
center shafts
http://62.2.107.106/~beat/images/25-...jan07_(35).jpg
fat cup
http://62.2.107.106/~beat/images/25-...jan07_(36).jpg
the watercooled schulze controller
http://62.2.107.106/~beat/images/17-...ewater_(4).jpg
http://62.2.107.106/~beat/images/17-...ewater_(6).jpg
Serum 01.25.2007 04:46 PM
Heya Rhylsader!
Who inspired you for that excellent pins in the driveshaft?! LOL
Nice project, i followed it on rc-independent.
That schulze thingy is something new.!
Mike.L 01.25.2007 04:50 PM
something new to my eyes and it must run cool:)
Sylvester 01.25.2007 05:07 PM
Looks very "cool"! :) I wonder how that schulze will run with water ;)
rhylsadar 01.25.2007 06:00 PM
yes serum that was a good idea with the pins. or let me put it the other way it was a quite unreflected idea to leave this with just one cross pin.
the schulze was very cool even on 16cells in the buggy. before he had always temp shut downs with 16 cells. there was an issue now with the controller and he sent it for reparation to schulze. they can fix it for 50euro. but i would have liked to see matthias' face when he saw that heat sink with milled channels in it. :005:
bye
rhylsadar
