-   Fastlane Machine (https://www.rc-monster.com/forum/forumdisplay.php?f=22)
-   -   FLM super chassis kit (https://www.rc-monster.com/forum/showthread.php?t=5473)
My_stampede 01.26.2007 10:17 PM
I was curious if when someone order's the super chassis kit if they could get widened front arms and regular rear arms?
on my plastic stampede i already have hpi wide front arms and front rim on rear to match the front width...
Would the width be the same on the flm arms?
my question basically is if i can get i like that. would using front rims on the regular rear arms match the flm's front arm wideness as it does the hpi way and or most other wide mods?
When they say its extended... does this mean you must still use front rims on rear? or are does the wheels line up how they did from traxxas? front on frt and rear on rear?
thanks for your time.
jnev 01.26.2007 11:46 PM
If you email mike before ordering the parts, I am sure he can help get the parts exactly how you want them. On my FLm stampede, I switched the front and rear rims and then they became perfectly even in the front and back. But, I also had the extended a-arms in the front and back, so it may be different if you order different sized a-arms.
Hope this helps. BTW - welcome to the forums.
crazyjr 01.27.2007 02:08 AM
There is a small window that when you click the blue square it will give you a choice
meatzardd 02.10.2007 11:05 AM
yes, u still need to use the stupid offset in the front and normal offset in the back with the extended.
