Brushless Cen Genesis
Hello!
Im quite new user here and im from Finland, so sorry for my bad english :027: Im converting cen genesis to brushless and im buying a new motor to it. I have already bk 20xl06x motor and 12020 controller, and I think the motor will be too hot.. So what kind of motor would be perfect? Some specs:
If someone could show me the light I would be very happy :027: |
Closest i could come for info for you is a GST 7.7 which should be nearly identical http://rc-monster.com/forum/showthread.php?t=4495, and welcome to the forums
What lipos are they? A neu or lehner are the top notch motors out there.
9kg is a heavy truck.:dft002: I would say that you want the Lehner 1950 for sure. The Neu 1515 would be an option but your BK12020 controller will not run a Neu 4 pole motor.
Couple questions. How many cells are your lipos? What is the capacity and C rating of them. For something that heavy I would say you want as much voltage as possible. You should consider running 6s (22.2V)Lipo if you can. On 6s lipo the 1950/9 would be a nice choice. Plenty of torque to get that big beast moving. :027: I'd love to see some pictures of you truck if you can post some. |
Aquwt has a 2280 on his
Yes I saw aqwuts conversion its pretty crazy :005: . But the thing is that I dont have so much money for lehner + controller. Finedesign has the same conversion even with smaller controller, how is that possible and they say it runs even better than stock genesis.. I started this project about half year ago and I just want to get that dam thing to move soon :027: Right now I have two 11,1 V 4200 (12 C) robbe lipos, so pretty bad lipos. I try to get some photos soon.. |
Welcome Hardstyle! i think it would be wise to get a lower KV motor. it would work with the one you have though, but you need to gear it tall, (same goes for the lipo´s) it will work, but you need to gear it for a low speed.. the motor still is hot though.
If you can swing it get a lower KV motor. (on 6S a 9XL or even a lower KV would be nice) perhaps the Robbe lipo´s are numbered with caution and maybe they can push out more. The XL motors can pull that sled, no worries. |
Ok! I have ordered 9xl but there are some difficulties in bk-electronic so I can still change the order to lower kv, would 10xl be better or maybe even lower?
Im thinking of buying new maxamps lipos, but im not sure can I use my old charger to charge them? My charger is robbe lipomat 5-4000 and it charge lipos by using voltage sensor socket. |
What speed are you looking at? Sorry for the late reply.
I know with that motor I cant get any crazy speeds but, something around 50 to 60km/h. So if it could go a bit faster than the nitro version, I would be happy :027:
What motor/lipo set would be good. Im thinking that I buy them from here, would that be wise? And second thing about the charger, can I use it to maxamps lipos? |
What i would do to toss that sled around;
warrior 12020 6S2P maxamps 8000mAh cells 10XL/11XL that would be good for nice runtime/power. |
Ok thanks!
I look into it, just in case I try 11XL... |
12XL would work as well. Longer runtime.. you made a wise choice in not trying to make it a 50mph truck...
Heheh, Maybe in future :005:
If you get good batteries, you might succeed in doing so with a higher KV motor.
| All times are GMT -4. The time now is 04:47 AM. |
