-   GorillaMaxx (https://www.rc-monster.com/forum/forumdisplay.php?f=16)
-   -   Grease G2R single speed tranny? (https://www.rc-monster.com/forum/showthread.php?t=5523)
Larain60 01.31.2007 12:05 AM
I looked around and there seems to be mixed opinions.
With Mike's idler and the Gorillamaxx single speed in a G2R, should I put some grease in the tranny on the gears?
Thanks.
BP-Revo 01.31.2007 12:48 AM
Yes, you should, as with a Steel Idler there will be metal on metal contact. Not doing so will most likely result in premature wear. After I greased mine my transmission was smooth as silk.
The stock tranny can be greased, but its unnecessary. The stock gears are teflon and are self lubricating.
jhautz 01.31.2007 03:00 AM
anywhere there is metal to metal contact of moving parts you should lubricate it somehow to prevent wear. The Emaxx transmision with steel idler gear is no exception.
Dafni 01.31.2007 03:11 AM
Originally Posted by BP-Revo
...The stock gears are teflon ....
I highly doubt this :032: A solid teflon gear would not stand a chance.
The stock gears are probably nylon or delrin.
Just my feeling.
BP-Revo 01.31.2007 03:43 AM
Just my feeling.
Blah...sorry...nylon is what I meant - my point was that they are self lubricating. :007:
Good catch :eek:
Dafni 01.31.2007 03:52 AM
I just had to say it :)
Procharged5.0 01.31.2007 05:39 PM
Nylon is correct.
I think you guys just like to talk about "self lubricating".....:005:
Bomb-Proof 01.31.2007 06:47 PM
Always grease the transmission, pack as much in as you can. Stock transmissions benifit from this as well. The reason we started running grease in them was to absorb impact on the gears, and it works quite well. It will also lubricate the gears of course.
BP-Revo 01.31.2007 06:51 PM
LOL
Pack in as much as you can? That takes away power though...(more resistance) as it starts acting like a diff.
Procharged5.0 01.31.2007 06:57 PM
Yep. I knew it.
"self lubricating"
"pack in a much as you can"
U guys are too funny........or were they both just Freudian Slips?
Sylvester 01.31.2007 07:10 PM
LMFAO. You guys are too much! You can even make a tranny question somthing dirty! ;)
Procharged5.0 01.31.2007 07:11 PM
On a more serious note. One of my projects has been to develope a high-perf lube for the E-Maxx/G-Maxx trans. It was developed in conjunction with a high-performance automotive lubricant manufacturers and input from a second. Thru their "pet project" research division we came up with a unique lube. It is engineered with a super high "cling" capability to prevent being flung off the gears, it's synthetic (cleaner, longer lasting, higher film strength, etc.) it has an EXTREME cushioning capability. This product is ready to ship but I was planning to release it with the HSR slipper kits.
Works much better than grease.
Bomb-Proof 01.31.2007 07:23 PM
It will techincally take a minute amount of power to spin the greased transmission, true. But a broken transmission is not as fast as one with all gear intact. And we had no less than 3x more power than needed at any given time. We came up with a good combination, no idea what the formula is anymore, it was supplied with all the ultramaxx gears. Synthetics are the way to go for sure.
Larain60 01.31.2007 10:33 PM
ok greased tranny- smooth as silk. Thanks guys.
