Quick Ext. Chassis Question
How well does the extended dogbone work with the FLM chassis? How does it install?
I see there is only one dogbone, is only one side extended away from the tranny? Thanks. |
Welcome to the forums!
It fits like a glove, all you do is take out your rear stock driveshafts and put in the cups following dogbone. The rear is extended, the front is regular length. |
| All times are GMT -4. The time now is 07:07 AM. |
