-   -   Efficiency of Lehner motors (https://www.rc-monster.com/forum/showthread.php?t=5589)
Hayden 02.05.2007 06:55 AM
Does anyone know what the Efficiency of the Lehner motors are?
Does it vary from size or kv of the motor?
I think every model of motor is different they will have a different sweet spot where it has its max efficiency at a certain rpm...etc..
Sylvester 02.05.2007 09:28 AM
The sweet spot for lehners are around 35K.. I think they are 85% efficient under partial load, maybe Rene or somebody else could scope in on this.
Hayden 02.05.2007 10:06 AM
I think their over 90% efficient but I could be wrong
I think that’s one of the reasons why lmt motors are so expensive
Sylvester 02.05.2007 10:19 AM
They are very efficient. They are expensive for several other reasons ;
Hand wound
Segmented magnets
Made id Germany :)
GERMAN ENGINEERING IN DA HOUZZZE! ;)
MetalMan 02.05.2007 07:19 PM
Efficiency will vary a bit. Factors include voltage, wind, load, etc. I imagine the efficiency range for our use will range from 60%-90% with the Lehner motors.
Hayden 03.01.2007 05:04 AM
I was referring to the efficiency % that they state in the specifications so I can compare motors.
Isn’t it the efficiency that counts mostly?
If these lehner motors are so good (and they are!!!) why don’t they supply specification with them? When I got mine and I just got the motor in a tube and that’s it:030:
Serum 03.01.2007 05:57 AM
Nope, efficiency is one thing, but it needs to be at a certain load.
Here, check this site;
http://lehner-motoren.com/motordia.php?la=en
GriffinRU 03.01.2007 09:29 AM
I guess it is not clear how to use my program...
Serum 03.01.2007 11:12 AM
This is measured data, not calculated.
GriffinRU 03.01.2007 10:53 PM
Measured only key motor parameters, the rest is calculated as well.
BP-Revo 03.01.2007 11:25 PM
I randomly clicked one of the 1940 specs and efficiency was 91%...damn.
Serum 03.02.2007 02:39 AM
I have got no idea what you mean.
BrianG 03.02.2007 02:49 AM
I want a 110% efficient motor...
Serum 03.02.2007 02:58 AM
Good point, we don't need a superconductive controller to get to a 100 percent total efficiency that way..
BP-Revo 03.02.2007 03:06 AM
111 here.
