-   -   locking tranny in 2nd (https://www.rc-monster.com/forum/showthread.php?t=5602)
entjoles 02.05.2007 07:34 PM
i use a center diff with front and rear brakes, my ? is if i lock my tranny in 2nd and still use a servo for brakes will it work properly? im thinking no but could use your help
glassdoctor 02.05.2007 08:02 PM
You lost me.... is it a center diff or center tranny? Revo?
jhautz 02.05.2007 08:16 PM
sounds like a revo tranny with the optional diff installed.... Right?
entjoles 02.05.2007 10:04 PM
yes revo tranny with center diff installed, if i lock the gears into 2nd will the diff work properly?
BP-Revo 02.05.2007 11:00 PM
It should be fine - the two speed assembly is seperate from the center diff assembly.
entjoles 02.05.2007 11:04 PM
but with the hv maxx i cant turn off the brake function, so it will stop the gears, right?
BrianG 02.05.2007 11:11 PM
Yes, if you lock the tranny in second, the motor will stop the truck. And you'll have reverse.
BigSushi 02.07.2007 10:46 AM
Will you still be able to use the Traxxas Center diff with the 2nd gear and still be able to use the motor brakes and reverse?
BrianG 02.07.2007 11:47 AM
Yup. First and/or second gear have nothing to do with the gear that drives the center diff (it's a seperate gear). I am using locked 2nd gear with a center diff (although it's a custom one, not the stock one).
To lock the tranny, you can either use the little adaptor by b0gh0s, or you can easily do this mod to do the same thing.
