-   -   quick question (https://www.rc-monster.com/forum/showthread.php?t=5646)
meatzardd 02.08.2007 10:42 PM
quick question
just wondering the safe amount of cells to run on a 9920 before i should be worried? would i be safe to run 16 cells on a 9xl, i would imagine things gettin pretty toasty so should i put a fan on the esc?
thanx
squeeforever 02.08.2007 10:50 PM
You shouldn't need a fan if its geared correctly. You also shouldn't worry unless your running right at the cell limit as well...
meatzardd 02.08.2007 11:22 PM
alright thanx, what type of gearing should i run with 9xl on 16 cells?
im runnin the stock spur wit a g maxx chassis and standard bowties.
thanx
Serum 02.09.2007 05:18 AM
Check Brians speedcalculator, it will help you out.
