-   -   Balance Flight Powers on Hyperion LBA6 (https://www.rc-monster.com/forum/showthread.php?t=5713)
Cartwheels 02.15.2007 01:42 AM
Are there any adapter wires that I can buy so that I can balance my Flight Powers on my Hyperion LBA6? If not what is a good balancer that will work for the Flight Powers?
Cartwheels 02.17.2007 02:28 PM
Ok, since I'm getting no replies I'm guessing there is no adapters you can buy to make a Flight Power pack tap fit onto a LBA6 Balancer. Anybody know a good balancer for Flight Power. I think it has the same tap as the Thunder Power.
BrianG 02.17.2007 02:44 PM
If there isn't an available adaptor, you can get the proper connector for each part, cut the other end off, and wire them up together. Mike may have some ideas or even something in stock. Even though he doesn't have tap adaptors listed in the store, he had some that he sent me so I could make my own dual pack Y adaptor.
Cartwheels 02.17.2007 08:41 PM
Making my own adapter is not a bad idea. I'll have to check into that.
Thanks!
crazyjr 02.17.2007 09:10 PM
Are the metal tips that go in the plugs universal? If so, you could just pull them out of one plug and into the other
Serum 02.18.2007 04:31 AM
The plugs as used on the flightpowers are pretty standard.
I made my own for the maxamps packs and the graupner balancer (basicly the same balancer)
crazyjr 02.18.2007 07:35 PM
So the Flightpowers are the same as the hyperion?
