would this work with the mm 5700?
Bye:018: |
oo its 1/8.. thats what i was asking!!!
you answered it!! thansk! |
You should get a CRT .5 and shove the MM in there...then it should be crazy fast.
i couldnt find the crt .5 on ebay.. might not be looking for the right thing or something but if someone could get me a link thatd be sweet!!
o lol... its a 1/18th scale.. i dont think i could have too muchfun with those... lol
anyone know of a nice 1/10 4wd stadium truck to make a project truck? i really like the jammin trucks but do they have any small enough? |
you could do the hotbodies one.
which hotbodies one?
The MM motor is a "S" can, which isn't quite enough for an 1/8th vehicle. "L" and "XL" work fine. I'm running a 10L on mine with no problem. I'm seriously considering a 7XL, I believe that AAngel runs one of those.
Sleeb |
well i wouldnt mind buying a 7xl motor but wouldnt i have to use like 12 cells? or a 6s a123 cell setup? my mm esc wouldnt be able to handle that...
or could it? |
Yes, the MM can handle 12 cells, but you should use a little bec regulator to keep it cooler. 7Xl and 12 cells would be a good setup... Actually the CRT .5 is going to be a pretty badass little truck. It's just a little smaller than a 1/10 buggy... uses buggy tires. They are supposed to be out by the end of the month. |
according to tower mid to end of march
well id have to see the size.. idk...
aw... i couldnt use 6s a123 then huh... i thought 6s and 12 cells were the same lol... like 5 volts off.. haha would that hot bideis be a nice truck? my mm esc could not handle 6s could it? |
The MM's have been proven up to 5S LiPo and 6S A123's. So..
| All times are GMT -4. The time now is 01:32 PM. |
