wheels turn in opposite directions... :-( please help!
when the front wheels turn forward, the rear wheels turn the opposite direction. what is the problem?
i purchase the FLM front combo bulkhead and is it possible for me to put the gears in backwards? when i assembled everything, it all went together so smoothly. i didn't think anything was wrong until i finished my build and went out for a test. is it possible that i somehow damaged my tranny? |
not having that rig I can't say for sure but I think if I put my LST diffs back in upside down they run backwards
hope this helps Steve |
All you have to do is flip the front or rear diff. So they won't turn opposite next time, just make sure you install the ring gear on the opposite side from the other.
dang...i had everything done and now i had to take apart the entire front again. :-( i took apart the front combo bulk and put the gear on the other side and it's working again. thanks for the quick replies guys!
That makes for a funny-handling truck huh?
:D |
i guess this is how you learn about your truck...
That truck is able to do tractor pulling contests without any other equipment.. Not bad!
| All times are GMT -4. The time now is 08:59 PM. |
