What is the best motor to put on the e-savage?
The title say most..
What's the best motor i can put into my E-savage with 4s lipo? I want a nitro killer in both acc and topspeed :D |
well, it kinda doesnt go up.
the lehner is, as the name goes, a basic. so it is their low end motor. the nue on the other hand is a high end motor. what would you want? also keep in mind that the nue requires a mgm compro or quark. |
a lehner is 36mm in diameter and a neu without fins 39. perhaps the 39 doesn't fit the e-savage?
Welcome to the forum bytheway!
yeah welcome aboard.
also with the basic xxl you have a 4mm shaft, no 32p pinion with 4mm bore. so that would have to be custom drilled.:026: |
Well, but 2000watt is more than all the other motors??
the std motor is a 550 sized, 55mm diameter? |
No, a 540/550 motor is 36 mm in diameter
the neu 15 series are in between 700 and 3000 watts.
the stock motor are 36mm. how much room do you have for your motor? |
Guys, cursing isn't helping any of us.
Jolly, it's not a contest.. Don't stare at the 2000 watt thing too long. Please read the sticky i wrote in the brushless section, it will explain quite a bit. |
sorry bout that.
keep in mind; the power the motor produces depends on the batts. |
66mm long, 40mm in diameter..
you have that much room?
then i'd say a neu 1512/2.5d 2000Kv or maybe 15122d 2600Kv but then again, what do i know:p |
i need speed too ! :P..
a feigao 8-10l have more kv than that? |
Did you read the thread i suggested you?
Now i did.... but i want a nitro killer in speed too not just acc.. so 45mph would be nice.. and thats why i'm reading here.. to find the right motor for me..
| All times are GMT -4. The time now is 09:12 PM. |
