? about the novak super sport PLUS
Will the novak super sport plus run the Feigao brushless motor 540 6s?
No one knows? I am new to brushless and I am learning what all the info means but still would like to have a clear answer as to what the max reccomended brushless motor that will run using this controller
No it won't. Needs a sensored motor.
Cool, Thanks,
What brushless motor would you suggest to run with this controller other than the Novaks? |
There aren't too many options. The LRP motor is an option, but I think the speed control is maxxed out with the Novak motor and would likely thermal if a hotter motor was used.
Stick with the novak, or upgrade to a complete new setup..
The controller is not the strongest one available for a hotter motor. |
thanks, I appreciate the info.
| All times are GMT -4. The time now is 12:55 PM. |
