-   -   mamba maxx and bk wanderer 7xl compatible? (https://www.rc-monster.com/forum/showthread.php?t=5993)
strodedawg 03.08.2007 09:11 AM
can these be used together and what are the pro and cons
thanks
jim
jollyjumper 03.08.2007 10:18 AM
some people have done this with great succes.
just need the right plug to connect the motor to the speedo.
AAngel 03.08.2007 05:47 PM
I'm not running the wanderer, but am running the Feigao 7XL, which is essentially the same motor. I'm also using the MM controller with 4S lipo. I have had no issues with the setup and it is very smooth. I had, at one time in the no so distant past, wanted either a Lehner or Neu motor very badly. After actually done my conversion and using this MM/7XL setup, I've just stuck with it. It's hard to beat for around 200 bucks.
I'm running this in a buggy with 14/46 gearing. My 6Ah packs barely get warm and cogging, if any, is negligible.
Soya 03.08.2007 07:59 PM
Are you running a UBEC?
Sylvester 03.08.2007 08:03 PM
Welcome to the forums!
Hes running 4s so i beleive he is.
architorture 03.09.2007 12:49 AM
What kind of runtimes and speeds are you getting with this setup? Do you have any idea how the 7XL compares to the 6XL?
AAngel 03.09.2007 02:06 AM
I'm running 6Ah 4S packs and am getting about 20 minutes of runtime in a track environment. As for comparing it to the 6XL, I think it's better. The 6XL, in my opinion, would be too hot for a buggy on 4S lipo. With the 7XL NOTHING runs hot. Everything is as I envisioned it would be for the track. I can run pack after pack and not worry about anything, except the occassional broken part.
As for the speed, I don't know. I set the buggy up to run on a track. It just so happens to be the fastest thing I've seen at our track. I did get it up to around 50 a couple of times when I was messing around in a parking lot with the gearing, but that's just stupid fast for an 1/8 scale buggy. The suspension just wasn't set up for it. If you're looking for speed, a buggy is not the way to go. Not without modification anyway.
