How big is the difference ?.
Im buying a LMT 1940 8t motor from mike to use in my mbx 5 buggy. I was using a 7XL. How big is the performance difference between the LMT 1940 8t & a 7XL, also what is the phyiscal size difference ?.
You can feel the quality difference in your hand ; it will run cooler and will have more power. The 1940's are comparable to size with the XL's ~ the 1950's are a bit longer than the XL's.
I sure the qualitly is better, i was really looking for a somewhat detailed performance report if thats possible . also are the endbells screwed on or do i need a clamp ?. |
The performance is amazing. You'd think you would notice a ton of a difference, but you only notice enough to make you happy, which, imo isnt bad.. No matter how low i gear my lehner, it never gets above warm, even on a hot day.. You will have NO problems whatsoever with it. The whole motor is screwed, not clamped.
I'm not positive about the attachment of the Lehner end bell.
The length of the XL is only 2mm shorter than the 1950 The length of the 1490 is 6mm shorter than the XL I believe the Lehners are around 90% efficient where the XL's are around 80% efficiency |
Im pleased to hear that the motor is screwed together & no clamp is needed. What do you consider a hot day in canada :005: .? A hot day in florida is 90 + If i could get my system to run cool even in that weather it will be even cooler in the spring & fall. |
Hottest it has gotten here would be 30C+ on a summer day.. :)
Whats that in ferenhite ?. Sorry i dont understand celsius :007: . Also mik esayed the 1940 8T will work great in the MBX5T i plan on getting . |
30C is 86 farenheit
Thank you it gets a little hotter than that down here :005: . If i can get motor & my ESC to run resonably cool in 90 + weather i'll be happy . |
| All times are GMT -4. The time now is 05:56 AM. |
