wheel shims
Hello Guys,
I guess Im wondering where can I get shims for the emaxx. The problem area is at the wheel area where the rim connects to the CVD. When I tighten the rim to the cvd the tighter I make it the wheel does not spin so freely. Someone had mentioned to put shims between the cvd and the hex that goes on the rim. But where can I get the shims to space it. I have none thats why. If you give me a place to get can I please get the link to the page. Thank you guys so much for all the help as usual. Makana |
One time will do Makana.
The shimms you need are put between the two bearings. It might look like the wheels is binding, but most of the time the two bearings are sitting too tight. With Proline 23mm adaptors, there are a whole bunch of shimms. Otherwise you could set with the teflon Traxxas shimms with a 6mm inner diameter. |
you know a site I can pick some of these shims up?
Shoot Mike an email, i am possitive he has got them in stock.
| All times are GMT -4. The time now is 03:53 AM. |
