-   -   G2r Gear Advice (https://www.rc-monster.com/forum/showthread.php?t=6063)
ALL BRUSHED UP 03.15.2007 03:56 PM
G2r Gear Advice
any Advice On How To Gear My Truck G2r 1940/9 On 5s 4800MAH With Emaxx Trans.? Thinking 66t & 20pin, looking for good reliable bashing truck
BP-Revo 03.15.2007 05:36 PM
I think 20's a bit high to start with. What about 18 for the pinion?
ALL BRUSHED UP 03.15.2007 06:02 PM
could i go up to a 70 or 72 spur
tallyram 03.15.2007 07:14 PM
i used the strobe setup geared from 13-18/51. that was with a 1950/8 on 5s or 6s. which slipper are you using, rr?
BP-Revo 03.15.2007 07:23 PM
BTW, if it is RR...better get a different one...that thing is actually worse than the stock one at handling high torque loads...the only difference is that it wont melt when its slipping alot.
ALL BRUSHED UP 03.15.2007 08:00 PM
Im Just Using The Stock Slipper, Any Other Suggestions Appreciated.
