Mamba Max BRUSHED question
When I am manually programming (at the track) My Max wont go to option #9 in order to change to a stock brushed motor. Is this normal? Or do I need to connect a brushed motor to do it?
FYI, I am running 1.07 software as the 1.09 gave me fits and shut down the controller. |
What does the manual say?
not a whole lot on this topic. It shows the wiring diagram, and is written to show it goes completley hrough the setup process every time. This isnt the case with mine anyways it goes up to step 8 and then reverts back to step 1 after that.
Does it work when hooked to a PC through the software?
That would be my next question Brian.. :p
but of course.
| All times are GMT -4. The time now is 10:17 AM. |
