Brushless motor recommendations
Which brushless motor/s are appropriate for this 1/16th truggy
http://www.myhobbydepot.com/servlet/...6-Nitro/Detail Weighs 2.4lb rtr and has a two speed auto trans. pinion/spur = 15/30 Stats: Width: 225 Height: 94MM Track: 120MM Length: 286MM Gear Ratio: (First) 11.2:1 (Second) 7.4:1 Tire Diameter: 72MM Engine: .05 Cu/in |
An MM 4600 setup on 3S would be nice. Or a Lehner 1920 to propell it around at warp speed..
Wow - the 4600 or 1920 would propel that itty bitty 16th scale model to warp speed indeed and not even break a sweat!!
It weights about the same as a light 1/10th touring car with all the alluminum Brian! 2.4lbs isn't considered light for a 1/16th!
Lovely!
Still, I bet that size motor will look funny in such a small car. That's the same size as the Photon, and that had a tiny motor in it and it still flew.
im shure the mamba 25 and the competion X on 3s lipo would be more then enough. Serum dont ya think 4600KV mm would be too mutch??
An 8000kv motor on 3s in a pretty heavy 1/16.. well thats asking for a barbeque! Who wants steak?! :)
The weight of the vehicle is rather high. An MM controller with a smaller wanderer in the 3-3500 kv range would be a nice setup too. Though 25A isn't much for a 2.4lbs vehicle.
| All times are GMT -4. The time now is 08:47 PM. |
