-   -   Quark 125b (https://www.rc-monster.com/forum/showthread.php?t=6107)
ALL BRUSHED UP 03.20.2007 09:24 AM
Quark 125b
Just Started Programing My 125b And It Doesn't Beep, Is It Supposed To?
BP-Revo 03.20.2007 09:42 AM
I dont think so...one of the reasons I didn't get it.
jhautz 03.20.2007 09:57 AM
4 leds give you the feedback. Follow the manual. the first time it can get kinda confusing, but after you get it figured out its a piece of cake.
joeling 03.20.2007 10:00 AM
Hi,
I think it does. Read the manual - towards the end, it indicates that there is a beep when programming data is saved. From my vague memory, it does that. The manual is not fantastic but some reading between the lines will get u there. BTW I own 2 Quark 125B & a Quark 33,
Regards,
Joe Ling
jhautz 03.20.2007 10:19 AM
There are little blips when a setting is saved, but the leds is how the quarks tell you what setting you are choosing. The blip in between settings is more just to let you know it saved it.
zeropointbug 03.20.2007 02:25 PM
It only beeps when connected to a motor, as it sends pulses to the motor to act as a speaker. It works very well actually, the start-up tune is pretty neat too.
Or wait, i just remembered, I don't know if it beeps during programing, not sure. some help i was.... :032: :005:
A4DTM 03.20.2007 06:44 PM
first, yes, it beeps after each setting.
second, thanks zero, when i got my quark i was sure it was beeping after each step, but when i went to program it about a week ago, it wasn't beeping during setup, so thought something might be wrong.. then re-programed it a few days later connected to the motor, and the tones returned.
do you have a link w/ more info about how the motor acts as a speaker?
BrianG 03.20.2007 06:55 PM
The controller simply sends a set of pulses of audio frequency to the motor in such a way that it won't move. Although, if you don't have the pinion on it, the shaft does move ever so slightly. The tones are made the same way that the "music" is made when running; by the coils vibrating. Some motors are more musical than others. My 10XL makes noise as it is running, but my Neu doesn't - and they both use the same controller. I imagine it matters how tightly the coils are wound...
