-   GorillaMaxx (https://www.rc-monster.com/forum/forumdisplay.php?f=16)
-   -   1st and 2nd runs = Disaster (https://www.rc-monster.com/forum/showthread.php?t=616)
MaxxFusion 05.23.2005 02:00 PM
Last weekend i finally got to take my gmaxx out. After about 5 minutes or so I saw smoke coming from the truck. I ran over and took the lid off. Here come to find that I almost completley melted through my spur gear. The slipper was too loose.
On Saturday I was was able to replace the spur gear and tightened the slipper all the way. The truck was fine then. So I was driving around the backyard taking it easy trying to get used to driving the maxx. I drives so different than my pede and rusty. I makes very wide turns. I dont know if that normal or if I have to make some adjustments. So anyway I was getting bored driving so cauction so I started getting trigger happy. Well it wasnt long after that I wrecked. I slammed into a treated 4x4 fence post that was cemented into the ground. Something had to give and it wasnt the post. Needles to say I have to rebuild work to do now.
Here is the damage done.
Snapped a RD Logic CVD
Bent the Upper Arm (Look kins of like a L)
Ripped the pillow ball right out of my RPM steering Block
Unglued all 4 tires from my rims.
Luckily I have the new version of the G# upper arms I havent put on yet. I hope that the RPM steering block is still useable. I will just have to get a new CVD and check out my steering bellcrank. I recently installed the Proline servo saver and am running the Hitec 645MG.
I will see about getting some pics of the damage.
:W:
HotnCold 05.23.2005 03:20 PM
Ouch.... - Man that blows hard - Your maxx was one of the nicest ones i've seen in a long while.... Those poles dont move at all do they ...
Serum 06.14.2005 10:08 AM
You need more ROOM for that truck!!
Got the truck 'online' again?
MaxxFusion 06.21.2005 07:42 AM
No not yet. I hope to get some time this week and get her fixed up. I need to adjust my steering too. It seems like its turning too wide.
braaap11889 06.21.2005 08:45 AM
Weak servo? Or somethings binding.
polarisguy6490 06.25.2005 10:05 AM
monster trucks do turn a lot wider than stampedes my friend had a stampede and it tured really sharp. You just have to get used to it i think. Otherwise what braaap said is probably the cause. (something binding/ weak servo)
MaxxFusion 06.25.2005 12:19 PM
Its not a weak servo. Its a Hitec 645MG and I took it out of my pede.
Its most likely my pillow balls. I need to loosen them up a bit.
braaap11889 06.25.2005 05:02 PM
loosen them and see if it works. The 625 aint the best servo for a MT get a stronger one like the 200oz airtronics or hiteccs new titanium gear servos peace out
gcurtis2121 07.02.2005 05:10 PM
servo saver
Hey MaxxFusion, are you using a servo saver with that servo? And if so, what kind? I've got the same servo, and even though it's got metal gears, I'd rather not destroy it!
MaxxFusion 07.02.2005 05:42 PM
I have the Proline servo saver. Its great for the price if you can find one.
gcurtis2121 07.02.2005 05:53 PM
Thanks, I'll go looking for one now.
braaap11889 07.02.2005 10:52 PM
Just so you know they have been discountinued.
MaxxFusion 07.03.2005 02:05 PM
Yes. That is why I said if you can find one.
Here is a used one.
maxxdude1234 07.03.2005 02:12 PM
I believe they can only be run on the T-MAXX and Sport-MAXX, does anyone know about this? Anyone run one on an E-MAXX, if so, I'm getting one of these.
MaxxFusion 07.03.2005 02:16 PM
I believe on the stock emaxx chassis you will have to hack off the plastic stand offs. Its been a while since I had a stock chassis.
