-   -   Brake issue (https://www.rc-monster.com/forum/showthread.php?t=6171)
phidailo 03.25.2007 09:17 PM
Brake issue
I have a quark 125/neu 1700kv setup with lipos. I finally got my maxx running again after a diff problem and notice a problem with the brakes. Sometimes after using the brake and releasing to coast the brakes will lock up and continue to brake for a few seconds or to a complete stop. Anyone experienced this or know what is going on?
Patrick 03.26.2007 05:09 AM
Is reverse disabled? It could be trying to go into reverse.
phidailo 03.26.2007 01:51 PM
Reverse is on the setting where the trigger needs to go to neutral first and then into the reverse position.
Patrick 03.28.2007 05:10 AM
Does it do only do it if you go - brake-neutral-brake again while the car is still rolling. When mine was on the same reverse setting as yours, if I did that, it would slam it into reverse while still moving.
If it does it while rolling in neutral, I don't know what it would be, unless you have drag brake set, the throttle trim is out, or you have a very small neutral point (if that's what it's called) set and any small movement of the trigger towards brake is enough to tell it to brake/reverse.
What does the Neu 1700kv seem like on 4s? I'm thinking about getting a Neu and/or lipos for my e-maxx, but haven't made my mind up about which motor and how many cells.
Serum 03.28.2007 05:15 AM
Yes, that's right Patrick.
With the reverse enabled you can't go back to neutral with this setting. That way the car just hits reverse. But as far a i am reading the opening post, i don't think that this is his problem.
Did you checked all the connections from the motor to the controller? are they healthy?
