-   -   number of cells vs MM motor (https://www.rc-monster.com/forum/showthread.php?t=6235)
david lamontagn 04.01.2007 11:31 AM
Hello, i'am to build my electric Jato, and i don't know wich motor to put in.
I've a Mamba max speed control and i look for the MM 4600 motor.
Could i use 3 cells li-po with this motor and how this motor is compare to Feigao motor????
Plus, is the MM motor have the same mounting hole spacing than the Feigao XL motor, because my engine mount was made to accept my hold Feigao 8 XL in my electric LSP, and i want to modify this engine mount to put it in my Jato.
thank you:030:
crazyjr 04.01.2007 12:26 PM
3s is no problem with a 4600, I run 3s on a 5700 with no troubles, bolt spacing is the same as XL or any other 540/550 motor
david lamontagn 04.01.2007 01:26 PM
Ok thank you crazyjr, i'll order a 4600 with a 11.1 volts li-po pack.
BrianG 04.01.2007 01:59 PM
I've built a Jato using only 2s on a 4600 and it is still fast (~45mph depending on gearing). On 3s, you should be able to get to 60mph.
