adapter
is it safe to make a 4 way adapter on a mrc 989 to charge 4 6 cell batteries that isnt going over the limit but will it charge the first pack more then the others
only recommended if the cells are used in series, same capacity, and balanced.
what is a good balancer for six cell batteries for around 70 bucks
Im charging two 8 cell packs with mine and I'm having no problems.
but you are using the cells in the same configuration as you charge them, correct?
That is correct |
so dose anyone no of a good balancer
| All times are GMT -4. The time now is 05:18 PM. |
