Help with diffs
OK i am disassembling my HB buggy diffs for my emaxx. i am disassembling them to use a custom shaft mount to accept sliders. My problem is that i can not get the bottom diff cup out because i can not get the pin out of the diff that holds the diff cups in. what should i do
There should be a setscrew you remove and then push the pin through there...
yeah just figured that out 2minutes ago while i was cleaning them thanks anyway
No problem.
| All times are GMT -4. The time now is 05:36 PM. |
