Heat gun ?
Hi everybody :017:
Do any of you know of a company that makes a 12v heat gun, if so can you prvide a link please ?. THANK YOU |
I don't think you will find a true heat gun in 12v... best bet is a little hair dryer.
I would suggest a butane/propane torch with a "hot air" nozzle. |
Do you know of 12v Hair dryer?. I Would like to use it for heating up my motor off my starter box at the track . So my motor will be eaiser to start. |
It will suck a lot of juice from the battery... and I doubt they really work very well anyway.
google 12v hair dryer or 12v auto accesories.... they are common for truckers, RVs, boating, etc.... |
Wow, a 12v true heat gun would suck some serious current. Most 120v ones draw ~10-15A. That is between 1200 and 1800w. To get that power at 12v, you'll need 100-150A! The best you could hope for is to get a 12v hairdryer. Or, use a 120v extension cord (but make sure it uses 12-14GA wire because of the current).
You can get 12v tyre warmers with heated blankets for models (some with variable temprature) maybe 1 of those with 1 blanket wraped round the head and 1 around the crankcase would work without draining your battery so much, you could even use the other 2 blankets on your tyres.
| All times are GMT -4. The time now is 10:03 PM. |
