what length shaft for front center FLM chassis?
I know it comes with the shaft for rear, but what about the front? What shaft can i use, I do have the RC-Monster extended CV's, will the short one be the right length? Or do I have to use a slider shaft?
the short one should work 72mm
Great~! Are you sure then? Then at least those won't be completely wasted...
i am pretty sure but let others chime in and tell you what they think.
This is the one that I used for my FLM setup and it fits perfectly (83mm assembled). http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXLSS8 |
1 Attachment(s)
K, thanks guys. I have no way of checking this yet, so this will have to wait another week or so. :024:
very helpful info thanks
zeropointbug i have asked this question before because i have a FLM chassis and i am pretty sure they told me 72mm. also 72mm is stock for the front the only difference in the gmaxx chassis is the extended rear the front is the same length same with the FLM chassis it is only extended in the rear. the 72mm should work because it is made to replace the stock part that is standard length. wait just to be sure or pm serum or one of the other guys that are high on the totem pole they should be able to help, but i am pretty sure it is 72mm that mike sells.
oh okay, yah that makes sense that only the rear shaft would be extended, just to keep things somewhat standard, and easy to adapt too...
Thanks again guys, I'd sure this will work then. |
When i ran my flm chassis. I used the ue ti shafts. I used a 70 up front and a 105 in rear.
1 Attachment(s)
I already have the extended steel shaft's Mike sells, I'm going to use them.
I also am using new MIP Shiny CVD's all around, Maximizer diff in rear, and older Kippster diff in front. I am going to get some Integy diff cases for now, I want to get some hybrid bulks eventually, OR some UE bulkless victories. |
With stock diffs standard maxx stuff is OK but carefull with hybrids - > thanks to longer diff pinion + drivecup you need shorter dogbone. I have a temporary solution in rasing the transmission by about 8mm but Mike is making me custom dogbones.
| All times are GMT -4. The time now is 02:32 PM. |
