-   -   diff oils/lube/grease? (https://www.rc-monster.com/forum/showthread.php?t=639)
maxxdude1234 05.28.2005 08:41 AM
hi,
I just brought a set of FLM diffs from here, but I have absolutely no idea what they should be filled with, or what lubricant to use on the ring and pinion gears.
Could you please reccomend which oils/lube/grease I should use from THIS website: http://www.modelsport.co.uk/?CallFun...egoryID=604010 (I live in the UK, so has to be a UK website)
The hpi heavy weight diff grease at the bottom looks quite good, but can i fill the diff cups with this (pic here: http://www2.towerhobbies.com/cgi-bin...?&I=LXDHK6&P=7 )
Thanks for your help :)
RC-Monster Mike 05.28.2005 10:09 PM
That HPI stuff in the second link will work perfectly.
supermaxx4190 05.28.2005 10:39 PM
when i had stock diffs, i just used stadard white grease. the stuff that goes in grease guns
maxxdude1234 05.29.2005 04:13 AM
thanks...
braaap11889 05.30.2005 06:20 PM
white marine grease.
