-   -   Stock revo conversion; (https://www.rc-monster.com/forum/showthread.php?t=6410)
Serum 04.14.2007 10:37 AM
Well.. After some inspiring days in Switzerland last year, i kind of fell in love with Dafni's revo's.. his basher-bitch, as he calls it, seems to be a pretty tough and ever going concept. (congrats on her Daf.. :) )
Made me want to make a revo that could hold almost all the available lipo-packs, and up to 16nimh cells (8 on each side). In order to make this happen, the mounting flaps for the front servo where in the way.. Well; this was the biggest problem I came across. nothing big though. More on this later, for now some pics about the ongoing process...
The frame without the flaps, left one small ear on it, for the radiobox. Since the frame is rather 3D, it's fair easy to work away all the wiring IMO.. (again, more on this later)
<a href="http://picasaweb.google.nl/buikpijn/StockRevoConversion/photo#5053290017044713986"><img src="http://lh6.google.nl/image/buikpijn/RiDkfzz6UgI/AAAAAAAAAvI/klh7jn02Mtk/s800/CIMG5364.JPG" /></a>
since the two angles on the side of the frame have a different angle, this was needed to have both the batterieholders sit at the same angle;
<a href="http://picasaweb.google.nl/buikpijn/StockRevoConversion/photo#5053290029929615890"><img src="http://lh5.google.nl/image/buikpijn/RiDkgjz6UhI/AAAAAAAAAvQ/IAX9jKu4fH4/s800/CIMG5367.JPG" /></a>
Mounted, it looks like this;
<a href="http://picasaweb.google.nl/buikpijn/StockRevoConversion/photo#5053290042814517794"><img src="http://lh4.google.nl/image/buikpijn/RiDkhTz6UiI/AAAAAAAAAvY/Avh0AQdkzxE/s800/CIMG5368.JPG" /></a>
<a href="http://picasaweb.google.nl/buikpijn/StockRevoConversion/photo#5053290059994386994"><img src="http://lh4.google.nl/image/buikpijn/RiDkiTz6UjI/AAAAAAAAAvg/IVoTT_j-JlU/s800/CIMG5369.JPG" /></a>
<a href="http://picasaweb.google.nl/buikpijn/StockRevoConversion/photo#5053290072879288898"><img src="http://lh3.google.nl/image/buikpijn/RiDkjDz6UkI/AAAAAAAAAvo/ukD44Di2rZY/s800/CIMG5370.JPG" /></a>
The CF angle come from Graphite Elegance.. 1/8th thick, 2X1" angles, i will make it lighter once all the holes are in place, I'll give them a neat shape.
<a href="http://picasaweb.google.nl/buikpijn/StockRevoConversion/photo#5053290098649092690"><img src="http://lh5.google.nl/image/buikpijn/RiDkkjz6UlI/AAAAAAAAAvw/MwCJuLyuoBA/s800/CIMG5371.JPG" /></a>
Perfect for 8 Nimh's;
<a href="http://picasaweb.google.nl/buikpijn/StockRevoConversion/photo#5053290120123929186"><img src="http://lh6.google.nl/image/buikpijn/RiDklzz6UmI/AAAAAAAAAv4/ub_BqKue3lU/s800/CIMG5372.JPG" /></a>
steering servo hang out; (used an FLM servo mount to hold her in place)
<a href="http://picasaweb.google.nl/buikpijn/StockRevoConversion/photo#5053290141598765682"><img src="http://lh3.google.nl/image/buikpijn/RiDknDz6UnI/AAAAAAAAAwA/vSXNYo7Ux34/s800/CIMG5373.JPG" /></a>
And this is where it will be positioned on the frame;
<a href="http://picasaweb.google.nl/buikpijn/StockRevoConversion/photo#5053290197433340578"><img src="http://lh4.google.nl/image/buikpijn/RiDkqTz6UqI/AAAAAAAAAwY/hKRp4CkiQEs/s800/CIMG5376.JPG" /></a>
More to follow soon.
Dafni 04.14.2007 12:05 PM
... and the saga continues! :)
Serum 04.14.2007 03:39 PM
Small update;
Here is how the rear of the batterieholders are supported;
It also helps keeping the servohorn from bending, since it sits at the bottom of the truck.
<a href="http://picasaweb.google.nl/buikpijn/StockRevoConversion/photo#5053369083097666226"><img src="http://lh4.google.nl/image/buikpijn/RiEsaDz6UrI/AAAAAAAAAwk/tS2sRkGj6J0/s800/CIMG5378.JPG" /></a>
The bulks needed a bit of work; Initially these holes are used for the nitro enginemount. they come out under an angle. I drilled the holes thru (straight) and put two screws in it, that are screwed into this threaded spacer;
<a href="http://picasaweb.google.nl/buikpijn/StockRevoConversion/photo#5053369113162437330"><img src="http://lh3.google.nl/image/buikpijn/RiEsbzz6UtI/AAAAAAAAAw0/vcX9uViBekA/s800/CIMG5381.JPG" /></a>
<a href="http://picasaweb.google.nl/buikpijn/StockRevoConversion/photo#5053369130342306530"><img src="http://lh3.google.nl/image/buikpijn/RiEsczz6UuI/AAAAAAAAAw8/Nl5qXBS0ueA/s800/CIMG5382.JPG" /></a>
and when put in place, it looks like this; Next thing to do is drill a few holes..
<a href="http://picasaweb.google.nl/buikpijn/StockRevoConversion/photo#5053369147522175730"><img src="http://lh3.google.nl/image/buikpijn/RiEsdzz6UvI/AAAAAAAAAxE/1dUlwOiSSW0/s800/CIMG5383.JPG" /></a>
Sylvester 04.14.2007 03:48 PM
Looks great!
squeeforever 04.14.2007 04:11 PM
Serum, looks great! I guess you plan on doing something like on the Dark Impacts where the servo is at the back and a very long aluminum rod runs from the front to back for the steering link?
Mike.L 04.14.2007 04:26 PM
Wow thats simply amazing i just wait for more! Keep it up serum!
GorillaMaxx360 04.14.2007 04:50 PM
nice serum.\
It looks very clean and neat just the way i like it
Serum 04.14.2007 05:33 PM
Squee;
the plan was, indeed, to use a long rod. I've got this 3mm titanium rod i can use as a turnbuckle. only need to make some thread on it, and it's good to go.
Just finished hooking up the batterieholders, still having doubts on how to mount the motor. (using a stock e-maxx transmission) My initial idea was to make a motorplate that enables the motor to sit on the opposite direction of the transmission. kind of like the original gmaxx mount, only fixed to the gearbox. (this way i could mount the motor lower) It would use spacers to mount the motor onto another plate.
Good thing is i've got some driveshafts wandering around that are a perfect drop in for front and rear.. So basically, this project comes together pretty easy!
squeeforever 04.14.2007 05:55 PM
Serum, there was another member around here that did the same thing, I just can't remember his name. He had a Ofna Hyper 7 PBS buggy with a Maxximum and 18.97, and a Revo conversion that he had the same setup in, but sold the Revo for the buggy and then sold the buggy.
BrianG 04.14.2007 06:55 PM
Looks nice so far Serum! I like using the stock chassis too since it is more custom. Can't wait to see the finished product! Aren't you done yet? ;)
jnev 04.15.2007 03:08 AM
Looks great!! If I was to convert the revo, I would also use the stock chassis... you just ahve so many mroe options in where everythign mounts and how.
AAngel 04.15.2007 04:15 AM
Serum,
As usual, very nice work. Once I get off of my 1/8 scale kick, I'd like to do a Revo; but first, the Serpent!
MetalMan 04.15.2007 11:51 AM
That's a nice way to do it! Will you be running a center diff, or will you go with a "slipperential" type of thing like I have in my Revo?
Serum 04.15.2007 11:56 AM
I've got some parts to make a slipperential like diff, but i do have got the right shafts at this point to use the maxx tranny.. And i have got a maxx tranny, with strobe.. arh, a centerdiff would be my favorite. :) let's see if i know a person that can make me some shafts.. (wink)
Mr.lst 04.15.2007 12:50 PM
It looks good but we need to see the finished product now!!!
