-   -   Just a quick compatibility ?...... (https://www.rc-monster.com/forum/showthread.php?t=6458)
supralover72 04.17.2007 03:07 PM
Will a mamba max with a fegiao 8xl be ok and have enough power from 12 Ni-Mh cells? If not, what other motor can as the cell number is set.
jhautz 04.17.2007 06:43 PM
Yes it should be fine. On 12 cells the 7xl would be a little hotter/faster setup, but the 8xl will give better run time. Either should be fine. Make sure you use a UBEC with the MM on 12 cells.
BrianG 04.17.2007 07:02 PM
And I recommend a fan...
supralover72 04.17.2007 07:56 PM
Got the UBEC, ar ethe fans sold here?
Also, thanks guys.
jhautz 04.17.2007 08:00 PM
No, But he should carry them now that I think about it.
Try this for the MM ESC.
http://www.allelectronics.com/cgi-bi...LING_FAN_.html
5V runs off of the UBEC and fits right on top of the MM. 3mm screws goes right in between the fins on the heat sink. You could go with 40mm fans if you want more airflow.
HotnCold 04.18.2007 07:31 AM
you could check with mike about the fans - i know he has had some before....
supralover72 04.18.2007 03:08 PM
Thanks guys.
