battery Protection?
Hey Guys,
I'm looking to get some lipos for the e-revo now, but I want to make certain they are well protected from harms way and crashes while on the truck. This is only a track truck, and I'd prefer to keep the chassis I currently run, at least for a little while, I was thinking just some like C channel on the sides? I know alot of lipos are out now, anyone prefer one type over the others due to strength and safety? http://www.rcbros.com/uploads/images..._erevo_165.jpg http://www.rcbros.com/uploads/images..._erevo_166.jpg I'd like to get a123's but I need 45 minute runtimes. I'm running the Feigao 8xl and Warrior 9920. Normally 14 cells. |
Id reccomend 2 Trakpower Lipos. They have a hard plastic case so they are safe, imo they are safer than nimh :)
45 minute runtimes? I think you might could squeeze 45mins out of 8000mAh Maxamps Lipos. How do you hit that kind of runtime with NiMh's? I assume you have to change them out mid run?
If you could live with less runtime, I highly suggest Trakpower Lipos, especially from the standpoint of being able to take abuse. |
I don't get anywhere close to that runtime, which is why I want to go lipo...
How much run time are you get right now with the nimh packs? Also, what keeps your packs held in place?
Thanks |
If you want tough, you might want to consider the A123 cells. Lipos, even the ones in cases, are still relatively easy to damage.
I run all of my lipos in either aluminum or carbon fiber trays that leave nothing exposed but the top of the battery. I also got some foam padding to put into the front of the battery trays to add some protection in case of a frontal impact. I then use velcro on the packs and a strong nylon strap to hold the packs in the trays. I race and bash really hard and destroyed a few lipo packs trying to find a system that wouldn't let go of the batteries in a hard crash. |
Oh I c... I thought the ties was to hold the wires, didn't notice until now that the wires are on the inside of the shrink wrap. |
It may be me, but I think the zip ties are just temporary... unless they seem to be working out for you.
Zip ties for now, Velcro later.
I would like to run A123's but last time I checked 45minutes wasn't possible |
Guys, why it seems that the revo is two times wider than the maxx?
Are the arms really wider? Or is it because the batteries are mounted vertically? |
Do you think you could mount up another 90 degree angle on the outside of the holder. Or ever better replace the 90 you have now with an U-Channel. Just be sure to get one wide enough to fit the li-po in. And if you really want to go all out, get a wide one and then pad it with foam.
| All times are GMT -4. The time now is 04:46 PM. |
