Short video of the Bomb-Proof Products truck!!!
Hi everyone,
I just made a few videos of the Bomb-Proof Products truck. One with 22.2v full throttle and the other with 36v not even half throttle. If only I had a center motor mount I could really do some real testing with the 44.4v. Hope you all enjoin this short videos. I will also be posting this in other forums. http://www.youtube.com/watch?v=E9RQl91EnF8 http://www.youtube.com/watch?v=IdCDDd7ydJg |
Nice!!!!!
A123 Batteries Soo BIG. How do you make them fit. Any videos driving on pavement? |
Wow, now lets see it on the street or dirt. I can't even imagine how fast it would go on 44.4 volts.
If I can get a motor mount made that will put the motor in the middle of the chassis, I can make the packs fit in there, but for now I can only do test it like that.
Are these trucks on sale yet?
Bomb-Proof still has parts to make them here is the e-mail racegrafix@aol.com. I'm going to modify the battery tray to fit the 22.2v lipos in the truck. I have to see if I can get a BK 3695 to run it. Hopefully Mike can see this and talk to BK to see if they can lend a hand.
Luciano, I'm gonna e-mail Mike tonight when I get a chance. He should be able to get it done for around $75 or so since 2 will be machined at the same nice.
That sounds really good.
I found a way to mount the 36v pack in the truck. I also took out the 22 teeth pinion and went with a 14 teeth one. If everything goes well with the 14, I'll switch back to the 22 for some speed runs.
Here is the pictures with the 36v pack in the truck:
http://www.rcpics.net/view_single.php?medid=84494 http://www.rcpics.net/view_single.php?medid=84493 http://www.rcpics.net/view_single.php?medid=84492 |
I just came back from doing a quick test run. The spur, pinion gears are fine. The front diff is fine, but the rear locked on me. The ESC and motor only got warm after a little over 5mins. of running. I'm thinking of installing a 16 teeth pinion, but I'll probably go with the 22.
Is it ballanced on each side of the chassis relatively similarly?
It is somewhat balanced. I couldn't get my video camera to work. I will see if I can borrow my friend's camera tomorrow.
New video of the Bom-Proof truck
Here is a short video of the truck in a small parking lot. I hope you guys like it. I'll make a new one, but with much more space.
http://www.youtube.com/watch?v=-yrzb2EYsug |
Those phaltline tires seem to have good grip on tarmac.. Good to know.
It looks pretty quick :) |
| All times are GMT -4. The time now is 03:58 AM. |
