-   -   how are bl t-maxxes? (https://www.rc-monster.com/forum/showthread.php?t=6511)
t-maxxracer32 04.21.2007 06:52 PM
hey guys i bought a supermaxx off ebay awhile back
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN:IT&ih=018
and amthinking of making it brushless... i dont wanna start this project if its not worth it. but in my opinion this truck will be awsome even though its a t-maxx....(t-maxxes arent the main racing trucks is what im saying)
but lmk how this project will be.
im thinking 6s1p a123 cells and prolly a quark andneu motor. i plan to make this truck perfect.
t-maxxracer32 04.23.2007 05:30 PM
noone? i hate upping these kinda threads but i wanna know! lol
BrianG 04.23.2007 05:56 PM
AFAIK, the T/E share the same front/rear ends and suspension. So whatever you would do to an E, you'd do to a T. Don't know much about the tranny, might be easier to simply use an E tranny. Basically, it looks like people simply use an E to start since it's already electric.
Pretty much ANYTHING can be converted, it's just a matter of how much time and work you want to invest IMO.
t-maxxracer32 04.23.2007 06:30 PM
well what would happen if i made a custom mount for the motor and just connected everything?not changing the tranny or anything. how would that work?
thanks
BlackedOutREVO 04.23.2007 06:47 PM
or get a flm e maxx chassis, and the tranny and its a e lol... but u might be able to drop in a e tranny
t-maxxracer32 04.23.2007 07:05 PM
well its just the point that i already have this truck and i think i got a good deal on it. i would have only spent 350 on the rolling chassis after selling the engine and everything that is not needed for gas. pretty good deal in my opinion so i figure i should just use it instread of buying everything else new.
will it work as a drop in replacement? (gas to electric) as far as the tranny goes...
thanks
BlackedOutREVO 04.23.2007 07:19 PM
idk, i dont think so tho, i think the t maxx trans is bigger, but idk
Gustav 04.23.2007 08:39 PM
you can just make a motor mount and use the t-maxx tranny as it is,i fail to see why not,if you leave the tranny as it is you'd have to keep the mechanical brake(no bad thing) due to the one-way bearing in there.
If you don't want to fabricate anything then just drop an e-maxx transmission in there,should drop right in(e-maxx and t-maxx chassis rails are the same part so.....) .
The t-maxx has a shorter front drive shaft i think due to the brakes so you'll need a front drive shaft too if you go with an e-maxx transmission.Also e-maxx transmission outdrives are a different size too,6mm vs 5mm for the t-maxx.
squeeforever 04.23.2007 09:05 PM
Personally, a E tranny would be a wise choice. It would make things alot more simple. Gustav is correct as well, the E tranny will just drop right in.
GriffinRU 04.24.2007 12:33 AM
Sometime ago used T-maxx chassis to build this...
No problems with tranny
BlackedOutREVO 04.24.2007 12:44 AM
hmmm good to know same size tranny, well then a e tranny and u got a super maxx =)
GriffinRU 04.24.2007 12:59 AM
You need a spacer in between tranny and chassis, but that is simple
t-maxxracer32 04.24.2007 01:39 AM
ya i will figure it all out once i start building it but i have alot to do before. so it will be a while. i just wanted to make sure this wasnt a waste of time..
but!
i have a racing revo coming in in about a week. vantage chassis all the good stuff. would that be a better deal?
thanks guys!
