Bearing replacement in 7XL. How hard?
Just got done replaceing the bearings in my Maxx with some Acer bearings. Someone here mentioned replacing the ones in the motors as well. I would like to do this to my dual 7XL's. It looks like the ends are crimped on. How hard is it to take these motors apart to get to the bearings?
Thanks. |
All you need to do is smack the shaft one good one and it will come apart...Just don't looks the spacers.
Thanks squee. What about putting it back together? I have Mikes motor clamp/heatsinks so maybe not too big of an issue?
Thanks. |
Yea, just tap the endbell back on with a mallet and put the heatsink on to keep it together
I've done this on a few of the BK S can motors. As long as you have the heatsink/clamp to hold it together it's easy as pie. You installing ceramics?
Sure am. Already installed the full set on my Maxx and wow what a difference. Everything spins so freely now. I took the motor apart last night and checked the bearings on that. Ceramics should make a huge difference on that as well. I wasn't impressed at all with the smoothness of the bearings in the motors.
What size of bearing does your motor use? Are you replacing them with the sealed ceramic bearings from Acer?
Yes, ceramic nitride bearings from Acer. Size is 11mmx5mm and it is 5mm wide.
Here's another choice for motor bearings:
http://www.offshoreelectrics.com/pro...5c-yzz%235-nb2 How much are the Acer ones? |
The boca bearings seems to work for me... I wonder how the acer bearings compares to it...
I am very impressed with the Acer bearings. I know nothing about the Bocas though I'm sure they are good as well.
I did a spin test on my diff bearing. Stock bearing spun for about two seconds then came to an abrubt stop. Acer bearing spun for about 15-16 seconds before coming to a stop. I could blow on it and it would spin. Acer bearings are about a $1 cheaper (each) and include free shipping. |
avidrc.com is getting more and more ceramics in as well. $5 each if they have your size.
Great prices but unfortunately they don't have my size.
Will the ceramic nitride hold up to the high rpm's that a bl will put out?
Thanks. |
| All times are GMT -4. The time now is 01:25 AM. |
