-   -   kyosho center diff? (https://www.rc-monster.com/forum/showthread.php?t=6528)
BlackedOutREVO 04.23.2007 12:24 AM
kyosho center diff?
where can i buy a complete cd? and how much are they?
or are ppl using the hb cd, and then the kyosho spur for it?
RC-Monster Mike 04.23.2007 12:32 AM
Either way works - Hot Bodies parts are generally less expensive than Kyosho, so a HB diff with the Kyosho spur is likley the lowest cost solution. :)
BlackedOutREVO 04.23.2007 12:34 AM
thanks, any links or anything?
jnev 04.23.2007 01:09 AM
Here is the hardened diff:
http://www.rc-monster.com/proddetail...RO_DIFF&cat=17
You'll find the rest here:
http://www.rc-monster.com/gears.php
BlackedOutREVO 04.23.2007 01:15 AM
thats the rear, or front diff, thanks tho, i found them at tower hobbies... these things are expensive tho lol!
jollyjumper 04.23.2007 02:23 AM
http://www.amainhobbies.com/product_...oducts_id/8541
thats a front/rear, but you need to change the gear anyway 'cause the plastic spur is never included, even if you where to get a center diff.
skellyo 04.23.2007 11:01 AM
The cheapest solution for a HB center diff is to find a Lightning being parted out on eBay. I routinely see the center diff's go for $18-20, then you just need the $5 Kyosho spur from Mike.
BlackedOutREVO 04.23.2007 11:17 AM
thanks guys!
jw, i dont even really want the cd, just to keep the transmission small, is there some kind of spool? i rember like a ofna denominator or something, is that any cheaper?
jnev 04.23.2007 06:07 PM
Skellyo - if you happen to see a HB center diff on ebay, can you PM me the URL? That would be great.
Thanks
Edit: Nevermind skellyo. Just found two of them.:027:
