brushless set up help
Hey guys im new here but i aint new to rc but kinde of new to brushless, i got a hv maxx for my e-maxx and love it. And I was just wondering if this motor and esc would properly work together and how many cells i would need to use, and if there anything i should know about the motor and esc, like do they have a bad reputation ???
nemisis 10L brushless motor BK warrior 7018 brushless esc thanks |
What are you going to use it in?
If it is a maxx, you'd be better off with an XL feigo 540C motor and a 9920. It 'll run a lot cooler. An L motor will tend to get hot, for example, Like 14 cells, go 7xl or 8xl with the 9920. |
well im asking about this set up cause im getting i a good deal on it, i plan on putting it in my xxx-t for abit then im gona put it into a maxx
To be honest that not a very good system for either truck you are planning to use it in. Th 10L is to big and low KV for the XXX-T, and the 7020 is to small for the e-maxx.
I'd pass on that setup and spend a couple extra bucks and get something that is right for the truck you want to run it in. |
ok, I see, what do you mean about the 7020 being to small for a e-maxx??? and also i whant a motor with lots of torque for my xxx-t and its only gona be in there for a couple weeks, then its going into my brother maxx mudder project
| All times are GMT -4. The time now is 03:58 AM. |
