Micro-t help!
I have a BB motor installed in my micro-t with a lipo battery. After running for 10 minutes on Monday, the motor will not turnover when trottle trigger is pulled unless I give it a little twist with my fingers. As long as the shaft is turning, the trottle will speed up and slow down the motor, but when the shaft stops, I must restart it by hand. Is this a bad motor or esc? Help!!
You fried your motor I think. I had the same happen with my stocker and 2S LiPo.
Same here on my stock motor and 2s LiPo. Although it only does it once the motor starts to get warm, then I have to give it a little push to get it going. So what is a BB motor?
It's a high performance motor for the micro-t. It was a blast while it lasted.
| All times are GMT -4. The time now is 12:34 PM. |
