Fix for bending front lower pins!
I know this has been on here, but figured I would make a post dedicated to it. It has worked wonderfully for me, except loosing a e-clip every once in a while. And I just pulled my front end apart so I figured I would take better pics.
I found this brace on EBAY, is says its for the rear as a pin brace. But it will also work on the front. All you have to do is grind the ends down enough to be able to put the e-clips on and clear the steering bellcrank. Easy to do with a grinder, or dremel. I was bending front lower pins almost every run, I havent had to replace one since I put this brace on. Good Luck and hope this will help someone!:027: http://i70.photobucket.com/albums/i1...xxBrace013.jpg http://i70.photobucket.com/albums/i1...xxBrace022.jpg http://i70.photobucket.com/albums/i1...xxBrace019.jpg For some reason I cant get the pics to show, you will have to click the links. |
Ya thats my truck also, just thought since I had a chance to get better pics I would make a deticated post for people to find it easier. RcBro actually posted that after I did in that thread. But hey the more its out, the easier to find! Thanks!
| All times are GMT -4. The time now is 03:55 PM. |
